Have had a long break, I'm now back am back at it over summer.
I had a terrible time trying to get the axles out of the hubs. Had the specialty tool which clamps via the wheel bolts and drives the a bolt through the centre to push the axle out. Long story short, it didn't work. Decided to remove the whole assembly instead.
The brake pads were a bit tight removing them. Is there any way to open the callipers up a little? I imagine the others will be a tight fit.
I replaced the water pump as well as a precautionary measure.
New vs. Old:
Now I'm going to start pulling out the manual gear from the donor car. Does anyone know of some good diagrams for the vacuum hoses? I've had a few snap and want to re-run the lines.
Thanks! Happy to be active again!
